Optical Flow
Optical Flow
Analyses an image and visualise the movement of objects in the scene.
This node attempts to analyse an image and visualise the movement of objects in the scene, using different techniques depending on the mode selected.
Previous Frame Blend How much of the previous frames blend with the current frame.
Previous Frame Directional Dependence How much the directional movement of the previous frame affects the current frame.
Num Levels How many levels of motion can be tracked.
Optical Flow Mode Change the way the optical flow motion is calculated.
  • High Quality : Uses a block matching algorithm for reasonably accurate tracking.
  • Motion Vector Estimate : Generates smoother motion vectors but far less accurate.
  • High Speed : A simple technique using gradients and frame differences. less accurate than high quality, but much faster.
  • NVIDIA : Uses NVIDIA optical flow.
Output Velocity Magnitudes Forces the output to only show the magnitude. this only affects the output image, and not the internal motion vectors.
Output Velocity Angle And Magnitude Outputs both the velocity angle and magnitudes. this only affects the output image, and not the internal motion vectors.
Optical Flow Scale Scale the movement that is output.
Num Dilate Passes How many times the dilate pass is run.
