Morph Deformer
Provides controls for Blend Shapes / Morph Targets from the connected mesh
This node allows you control any Blend Shapes / Morph Targets which are available for the attached mesh.
Notch only support Blend Shapes from FBX and Alembic mesh formats.
| Morph Names | The name of the blend shapes you are looking to control. |
| Blend Mode |
Control the morphing behaviour.
| Weight Controllers | Allows for weightmaps to be input to modulate the blend shapes. | Image Plane |
