Range Remap
Range Remap
Remap the overall colours of an image.
This node remaps the colours of an image from the range specified by In Min and In Max to the range specified by Out Min and Out Max.
In Min The minimum channel value of the incoming range.
In Max The maximum channel value of the incoming range.
Out Min The minimum channel value of the outgoing range.
Out Max The maximum channel value of the outgoing range.
Clamp Range Toggles whether colours that fall outside the in min and in max range should be clamped to it, or whether the remap range should continue outwards beyond the range specified.
