Multiplex Sources
Takes multiple video inputs and outputs a single video based on the Source Index attribute.Updated: 15 Sep 2026
Takes multiple video inputs and outputs a single video based on the Source Index attribute.This node takes multiple video inputs and outputs a single video based on the Source Index attribute. All connected video nodes are treated as active, even if they are not currently being used.
| Preview In Viewport |
| Apply PostFX Before Alpha Image Input (Legacy) | When enabled, the alpha input image is applied after the postfx pass, overwriting any effects the postfx would have applied to the alpha channel. |
| Legacy Effect Mask Blend | Blend input masks using the legacy behaviour kept for pre-2022 scenes. Leave disabled for new compositions. |
| Source Index | Select the source video to use from the input source. |
| Sources | Add sources to select from. | Video Loader |
| Effect Mask | Mask out areas that Post-FX applied to this node won’t be applied. | Video Loader |
| Alpha Image | Use a separate video nodes luminance values to overwrite the alpha channel of the image. | Video Loader |
