Chunk Effector Deformer
Deforms geometry by transforming unconnected pieces with cloning effectors
This node moves unconnected sections of a mesh independently based on an input Cloning Effector. When used with Combine Geometry, each connected mesh will be treated as a unique chunk.
  • Local :
  • World :
Time Mode How the deformer updates with relation to the timecode..
  • Off :
  • Spherical :
  • Cylindrical :
  • Planar :
  • Procedural :
  • Cubic :
  • X :
  • Y :
  • Z :
  • Bidirectional :
  • Negative :
  • Positive :
  • Linear :
  • Sine :
  • Quadratic :
  • Cubic :
  • Circular :
  • Bounce Back :
  • Elastic :
EffectorsConnect a source effector to deform the mesh. Without an effector node added, no displacement will be made.Sine Effector
Mask ImageUse an image to mask out areas for the deformer to not function.Video Loader
