Direction-Weighted Motion Modifier
Evaluates how much a transform moves in a particular direction.
This node evaluates how much an input object moves in a particular direction, and outputs a modifier value based on it.
Cone Angle Movement cone angle for which movement within the cones direction will count toward the modifier.
Smoothing Adjust the amount of smoothing to applied to the output value.
Max Speed Set a maximum speed the modifier can read for a value.
Tracked NodeNode whose values will be tracked.3D Object
Direction ControllerThe input nodes local axes are used for determining the traced direction.Null
