Temporal Filter
Combines multiple frames together and filters out overlapping values.Updated: 15 Sep 2026
Combines multiple frames together and filters out overlapping values.This node combines multiple frames together and filters out overlapping values.
| Preview In Viewport |
| Apply PostFX Before Alpha Image Input (Legacy) | When enabled, the alpha input image is applied after the postfx pass, overwriting any effects the postfx would have applied to the alpha channel. |
| Legacy Effect Mask Blend | Blend input masks using the legacy behaviour kept for pre-2022 scenes. Leave disabled for new compositions. |
| Mode |
How the next frame is generated based on the frames before it.
| Num Frames | The number of frames previous to the current frame used in the filter. |
| Effect Mask | Mask out areas that Post-FX applied to this node won’t be applied. | Video Loader |
| Alpha Image | Use a separate video nodes luminance values to overwrite the alpha channel of the image. | Video Loader |
