Array Cloner
Array Cloner
Generates clones from an input array node.
This node generates clones from the currently active elements in a Transform Array node. Each element can spawn a clone, and the clone can inherit some properties from the transform array.
Rotations From Transform Array Use the rotations stored in the connected Transform Array to orient each clone, instead of each clone’s own rotation.
Scales From Transform Array Scales will be inherited from the input transform array.
Colour Clones Determines whether colour data from the transform array should be used to colour the clones.
Transform Array SourceSource Transform Array to generate clones from. An Array node must be connected for the cloner to generate clones.Transform Array
