Random Cloner
Generates clones with random transformations.
This node generates clones with random transformations within a specified area.
| Num Clones | Number of copies of the input object created by the node. |
| Node Spawn Mode |
Change the order in which the cloned objects are assigned to clone instances.
| Random Seed | The seed for the node’s random number generators. Change it to produce a different variation without altering the parameters. |
| Clone Scale | Scale the size of all the clones uniformally. |
| Scale Randomness | Adds randomness to the scale of each clone. |
| Spread X | How much the clone positions are spread across X axis. |
| Spread Y | How much the clone positions are spread across Y axis. |
| Spread Z | How much the clone positions are spread across Z axis. |
| Spread Heading | How much the clone rotations vary around the X axis. |
| Spread Pitch | How much the clone rotations vary around the Y axis. |
| Spread Bank | How much the clone rotations vary around the Z axis. |
| Rotate Clones | Allow the cloner to rotate clones at generation. |
| Scale Clones | Allow the cloner to scale clones at generation. |
| Seed | Select a random seed for the cloner generation. |
| UV Scale X Delta | Relative change to the uv scale along the x of the clone’s material, per clone. |
| UV Scale Y Delta | Relative change to the uv scale along the y of the clone’s material, per clone. |
| UV Offset X Delta | Relative change to the uv offset along the x axis of the clone’s material, per clone. |
| UV Offset Y Delta | Relative change to the uv offset along the y axis of the clone’s material, per clone. |
| Crop Left Delta | Relative change to the crop on the left of the clone’s uvs, per clone. |
| Crop Right Delta | Relative change to the crop on the right of the clone’s uvs, per clone. |
| Crop Top Delta | Relative change to the crop on the top of the clone’s uvs, per clone. |
| Crop Bottom Delta | Relative change to the crop on the bottom of the clone’s uvs, per clone. |
| Effectors | Control how the clones behave once spawned. See Effectors. | Plain Effector |
