Noise Shading
Noise Shading
Shades particles using fractal noise.
This node shades particles using values generated by a fractal noise function, similar to the Fractal Noise Generator node but in 3D. The noise function may be sampled by the position of the particle in 3D, or the life of the particle. Useful for adding flickering effects to particles.
Position X Position x in local space
Position Y Position y in local space
Position Z Position z in local space
Rotation Heading Rotation around y axis in local space
Rotation Pitch Rotation around x axis in local space
Rotation Bank Rotation around z axis in local space
Scale X Scale along the x axis in local space
Scale Y Scale along the y axis in local space
Scale Z Scale along the z axis in local space
Intensity Scale Scales the intensity of the resulting noise values.
Input Channel Choose how the noise affects the particles.
  • Position : 3D noise is generated and applied to particles based on their position in the scene.
  • Life : Noise is generated based on the particles life.
  • Life With Random Offset : Noise is generated based on the particle life, but is offset based on the particles position.
Radius Outer radius for which the particles will no longer be coloured.
Inner Radius Inner radius for which the particles will be coloured at their max.
Falloff Power How quickly the gradient changes from the inner radius to the outer radius.
Noise Colour Change the colour of the particles as they spawn.
Blend Mode Choose how the particle colours blend to the source colours.
Blend Amount Control how much the new shading affects the particles.
Position NodeControl the position of the fractal nose ion 3D space.Null
