Colour Curves
Updated: 5 Jun 2026
Remaps colour values using curves.
Updated: 5 Jun 2026
This node provides precise control over an image’s brightness, contrast, and colour by remapping input tonal values using editable colour curves. The master RGB curve can adjust overall shadows, midtones, and highlights while preserving colour balance, while the individual red, green, and blue curves allow for precise, per-channel colour correction and creative colour shifts.
In each curve, the horizontal axis represents input values and the vertical axis represents output values. By default, the curve is a straight diagonal line from bottom left to top right, meaning input values are mapped directly to output values with no change. By editing the curve you can affect the relationship between input and output values at any point along the curve.
Double LMB in the curve editor to add a point.
Double LMB on an existing point to delete it.
| Apply To Solid Geometry Only | Toggle whether the effect should only apply to solid geometry, or the whole of the scene. |
| Apply To Filled Pixels Only | Only apply the correction to pixels with content, leaving fully transparent areas untouched. |
| RGB | Control the red, green and blue colour channels simultaneously. |
| RGB Curve | Boost or reduce the values of the red, green and blue values simultaneously along a curve. |
| Red | Control the red colour channel individually. |
| Red Curve | Boost or reduce the values of the red channel along a curve. |
| Green | Control the green colour channel individually. |
| Green Curve | Boost or reduce the values of the green channel along a curve. |
| Blue | Control the blue colour channel individually. |
| Blue Curve | Boost or reduce the values of the blue channel along a curve. |
| Effect Amount Image | Input to control the amount of the effect based on the colour data of an image. | Gradient |
