Ripple Effector
Ripple Effector
Modifies a cloner system with a ripple effect.
This node applies a simple ripple animation to the clones it is applied to. The ripple is defined by its speed, sharpness, scale, animation rate, and repeat rate; altering these properties can produce a wide variety of ripple effects.
Animation Rate The global animation rate for the ripple animation. Useful for speeding up or slowing down the entire effect.
Ripple Speed Speed at which the ripple moves outward from the ripple origin.
Ripple Peak Sharpness How sharp the peaks of the ripple motion are.
Ripple Scale Scales the microripples within the dominant ripple motion.
Ripple Repeat Rate How quickly the ripple animation repeats after the previous ripple.
Direction Control how the ripple animation is applied to the Cloner system.
  • Linear : The ripples spread outward from the y axis along the XZ plane.
  • Radial : The ripples spread out radially around the z axis, and time progresses in the positive z axis.
  • Spherical : The ripples spread out radially around the z axis, and time progresses in the negative z axis. Only position x is used to affect the clones.
