Pyroclastic Displacement
Add blobby noise to a procedural.
Applies a noise-based deformation to a procedural. The noise generated forms a dense fusion of blobs.
| Num Octaves | How many octaves of noise are generated. |
| Noise Scale | Size of the noise generated. |
| Amplitude | How greatly the generated noise displaces the distance field. |
| Blob Size | Controls the overall ‘blobiness’ of the displacement. |
| Animation Rate | When not zero, this property will control how fast the noise animates. |
| Colour 0 | If the renderer of the procedural generates colours, then this colour will be used for the deformed shape. |
| Colour 1 | If the renderer of the procedural generates colours, then this colour will be used for the deformed shape. |
