Kill Box Effector
Kill Box Effector
Removes clones from a cloner system within a specified area.
This node limits areas that clones can be generated in and removes clones which move into its region from the scene. The killbox area is described using the Falloffs defined in the Falloff section.
Space The transform space in which the Effector is processed.
  • Effector - World : use the effector’s transforms in world space.
  • Cloner : use the cloner’s transform space.
