Rigid Body Depth Image
Allows Rigid Bodies to interact with data from a depth camera.
The Rigid Body Depth Image node is used to allow Kinect depth to collide with mesh in the rigid body simulation.
| Flip Image | Flip the image in the y axis. |
| Static Friction | How much resistance there will be for rigid bodies that are at rest relative to each other to begin moving. |
| Friction | How much other rigid bodies will be able to slide along side this rigid body. When two rigid bodies of different frictions interact, the minimum value is used. |
| Bounciness | How much this rigid body will bounce off of other rigid bodies in the scene. |
| Density | The density of the rigid body. The density is scaled by the area of the shape to determine the mass of the body. |
| Advanced | TODO |
| Collision Radius | The radius of collision shape if applicable. |
| Collision Mode |
Mode for calculating collision if applicable.
| Depth Image | Add a depth image to drive the collision inputs, | |
