Diffuse Material
Diffuse Material
Add a diffuse rough material.
This node generates a basic diffuse material, similar to the default material node but without any specular settings.
The output material can be applied to any node which accepts a material input, such as 3D Objects, Particle Trails, or a Procedural Raytracer.
  • Off : Disables the use of the diffuse map for AO.
  • On : Enables the use of the diffuse map for AO.
Normal Map Intensity TODO
Baked Diffuse Intensity TODO
Rim Lighting Colour TODO
Rim Lighting Intensity TODO
Rim Lighting Falloff TODO
Resolution Limits TODO
  • Off :
  • Use Limits :
Max Width TODO
  • 16 :
  • 32 :
  • 64 :
  • 128 :
  • 256 :
  • 512 :
  • 1024 :
  • 2048 :
  • 4096 :
  • 8192 :
Max Height TODO
  • 16 :
  • 32 :
  • 64 :
  • 128 :
  • 256 :
  • 512 :
  • 1024 :
  • 2048 :
  • 4096 :
  • 8192 :
This node has no inputs.
Colour TextureA texture to apply to the object that defines its colour.Video Loader
Diffuse TextureTexture applied spatially to object that defines its diffuse map.Video Loader
