Mouse Point Array
Mouse Point Array
Generate an Array using the mouse cursor as a source.
This node takes the position and state of the mouse cursor and converts it into an array. When the left mouse button is pressed a new point is created at the cursor location; that point will be moved to follow the cursor until the button is released. As such, if easing is used, it is possible to have multiple points visible at once.
The cursor’s viewport position is mapped to the node’s bounding rectangle, as defined by the Bounds properties, in 3D space: if the cursor is in the top left of the viewport it will map to the top left of the bounding rectangle, and so on. If the goal is to have points appear in screen space exactly where the mouse cursor is located, the node’s bounding rectangle should be mapped to fill the screen for the appropriate camera view.
Transform manipulators are disabled for this node as they conflict with using the mouse in the viewport to generate points.
Whilst in Builder, the Mouse Point Array node must be selected in the nodegraph for mouse points to be recognised.
This node will not function in a media server, as the media server captures all mouse inputs.
Axis Select which axis the touch array should appear along
Flip X Axis Flip the X axis of the incoming Windows Touch data.
Flip Y Axis Flip the Y axis of the incoming Windows Touch data.
Apply Node Transform To Array Elements Only When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used.
Ease Points On Enable Point Easing in, so new points don’t immediately appear.
Ease Points On Mode
  • Linear,
  • Pow2,
  • Pow4,
Ease Points On Duration How long the points should take to fully appear.
Ease Points Off Enable Point Easing out, so removed points don’t immediately disappear.
Ease Points Off Mode
  • Linear,
  • Pow2,
  • Pow4,
Ease Points Off Duration How long the points should take to fully disappear.
Easing Affects Point Scales Apply the easing to the scale of each point in the array, not just their positions.
Easing Affects Point Opacities Apply the easing to the opacity of each point in the array, not just their positions.
Set the bounding dimensions of the incoming data, and the area within which points will be generated.
Left Set the left extent of the bounds.
Bottom Set the bottom extent of the bounds.
Right Set the right extent of the bounds.
Top Set the top extent of the bounds.
2D Bounds SourceSets the 2D area the point will appear within.Region Camera
