Gaussian Splats
Gaussian Splats
Updated: 1 Jul 2026
Add an imported gaussian splat to the scene.
This node renders a Gaussian Splat model imported from an external file. Gaussian Splats are represented as collections of oriented volumetric points, allowing highly detailed scene and object reconstruction from photogrammetry and neural rendering workflows while remaining efficient for real-time rendering.
Like other 3D scene nodes, Gaussian Splat nodes can be positioned, rotated, scaled and parented within a Notch scene. Splats can be illuminated using standard Notch lighting, allowing them to integrate naturally with other scene elements and rendering workflows. Gaussian Splats can be transformed and deformed using standard Notch transform and deformation workflows. However, unlike mesh geometry, the splats represent a captured volumetric dataset rather than a continuous surface. As a result, significant deformation may produce unexpected visual artefacts as the splats no longer align to reconstruct the original captured appearance.
The supported formats are:
Gaussian Splat (.PLY)
Edit Pivot TODO
Object Select the source gaussian splat resource.
Layer Index Select a specific mesh from a larger 3D scene.
Deformer Shader Select shader to use as deformer on the object.
Lit Toggle whether the object can be lit by scene lights.
Render As Boxes Render the individual gaussian splats as boxes.
Splat Scale Control how big the individual gaussian spats are.
Alpha Alpha transparency of the gaussian splat.
Shadow Alpha Alpha transparency of the shadows in the gaussian splat.
Emissiveness How much the gaussian splat emits light.
Motion Blur Velocity Scale Scales the velocity vectors used in the motion vector pass, primarily used for motion blur effects. Useful for exaggering or removing motion blur on specific objects in the scene.
Object Vertex Count Shows the original vertex count of the object.
Object Polygon Count Shows the original polygon count of the object.
Post-Deformer Vertex Count Shows the current vertex count of the Object after all the deformers have been applied.
Post-Deformer Polygon Count Shows the current polygon count of the object after all the deformers have been applied.
