Kinect4 Skeleton
Kinect4 Skeleton
Control skeletal rigs from a Kinect 4 Azure.
This node controls the Kinect Skeleton tracked from a Kinect 4 camera sensor.
To set up the Kinect 4 skeleton, follow the instructions here.
  • Kinect isn’t on or hasn’t been connected to Notch.
  • Kinect Skeletons have not been enabled in the project settings window.
  • A suitable skeleton hasn’t been found yet.
The Kinect 4 body tracking library is based on NVIDIA CUDA, therefore an NVIDIA GPU is required for body tracking.
A skeleton stream (*.skel) file imported into resources can be applied for playback to the skeleton node with no active sensor required. Capturing a skeleton stream file during sensor playback is performed from the Devices/Capture Kinect1/Kinect2/Kinect4 data menu or by using Alt+K (once to start, once to end recording).
To visualise the tracked skeleton joints and their orientations, make sure to enable bounding box visualisation “BB” in the Nodegraph and this node is selected in the scene graph.
You will need to activate the Kinect camera you want to use by going to Project > Settings > Video In / Capture > Kinect 4 Azure and enabling it. Otherwise, it will not be initialized by Notch. This is by design, so Notch does not lock the device from the use by other software when you are not actively using it in Notch
Kinect Skeleton Stream Kinect Skeleton stream (*.skel) resource for playback.
Use Active Skeleton When enabled, automatically select the currently active skeleton.
Sensor Index The index of the Kinect4 sensor to use.
Avatar Index Select which Skeleton to use from the avatar index. Only functional with Use Active Skeleton is disabled.
Input Skeleton Scale Scale the size of the input skeleton.
Smoothing How much smoothing is applied to the output skeletons motion.
Derive Rotations (Don't use Kinect SDK Rotations) Use internally calculated rotations instead of rotations from the Kinect SDK.
These properties control the playback properties of recorded Kinect 4 data.
Stream Start Frame Start frame of Kinect Skeleton stream playback.
Stream End Frame End frame of Kinect Skeleton stream playback.
Stream Frame Rate The frame rate to playback the Kinect Stream.
Hierarchy RootConnect the skeleton root node to drive the rest of the skeleton from.3D Scene
