Field Affector
Allows particles to be affected by forces from a field.
This node samples velocities from a Field node and applies them to particles. This can be used to apply motions generated on a field, e.g. via a fluid solver, and apply them to a particle system so the particles move with the field. The magnitude of the velocity is controlled by the Velocity Scale attribute and modulated by a random value which is constant per particle and weighted by the Randomness attribute.
Optical Flow nodes can also be accepted to drive particles based on a video feed.
This node requires a Field or Optical Flow node to be connected via the Field input.
| Velocity Amount | Scale the generated affector velocities. |
| Randomness | How much randomness is added in the particles movement. |
| Life Effect Coeffs | How much the particles are affected by the affector at different stages of the particles life cycle. Values 1 and 2 are control points used to control a bezier curve between values 0 and 3. |
| Apply Mode | Select whether the field force are applied as simple velocities or continuous forces. |
| Field Node | The field root node to use | Field 3D Root |
| Mask Node | Mask out areas that particles cannot spawn. | Image Plane |
