Quantise Effector
Quantise Effector
Modifies a cloner system by quantising all the clone positions.
This node restricts the possible range of values a clone can be translated, rotated, or scaled to. This means clones can appear locked to particular transformations, but jump to new positions as clones processed earlier change or animate. The Falloffs for this node are binary, meaning the effect is either on or off within the region and it doesn’t interpolate between the two states.
