Cloner To Array
Updated: 29 Jun 2026
Creates an array from a cloner system.
This node creates an Array from a cloner system.
This lets you take all of the visual effects you can achieve with cloner systems and start using them interactively. By feeding the array with a cloner system, you can then pick out individual elements of the cloner system and attach objects to them. For example, in interactive projects, attaching a Hot Zone via an Array Element Extractor, and detect a trigger whenever anything enters the space of one of your cloned objects.
See the Array Sources for an overview on the use cases of Arrays.
| Max Element Count | Max number of elements for this node to track. Essentially the maximum clone index that will be included in the array. |
| Low Latency (Slower) | Reduces the number of frames of latency by which elements are updated in the transform array. However the calulation will take longer per frame. |
| Apply Node Transform To Array Elements Only | When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used. |
| Cloner Source | Cloner to make array from. | Grid Cloner |
