MOVIN Point Cloud
MOVIN Point Cloud
Updated: 12 Jun 2026
Creates a highly accurate, world scale point cloud from MOVIN systems data.
This node takes a stream of data from the MOVIN motion capture system and uses it to display a highly accurate, world scale point cloud. A point cloud is a collection of points in 3D space, with x,y,x co-ordinates. In this node the points are represented with a collection of spheres, which have a user determined radius.
The data for the MOVIN point cloud is received via OSC, using the port that is configured inside of your Project Settings.
Once connected, the point cloud behaves like any other 3D Node, and can be used with any other nodes that take a 3D node as input, such as deformers, procedural meshes, mesh emitters etc.
Combining this node with a Hot Zone allows you to detect when a person has entered a region of the tracked volume. This is a very powerful way to trigger animations or effects interactively based on the positions and movements of audiences or performers.
OSC must be enabled and to match the output address and port in the MOVIN software. If there is no connection the node will be hatched out in red.
OSC Address The OSC address that the MOVIN point cloud date is being sent to. This must begin with a: /
Radius The radius of the spheres that will be instantiated on each point of the point cloud
Material Preview Preview the objects material in the viewport.
BSDF
  • Off :
  • Tangent Space :
  • Object Space :
Normal Map Intensity Controls the intensity of an input Normal Map
  • Off :
  • On :
Displacement - Use Polygon UVs Use the UVs of each polygon when applying Displacement
  • Solid :
  • Blend :
  • Clip :
  • Solid : The material is treated as a solid object, and does not blend with anything behind it.
  • Linear : The material is blended with the rest of the content in the scene.
  • Additive : The material adds onto the rest of the content in the scene.
  • Subtractive : The material subtracts from the rest of the content in the scene.
  • Multiply : The material multiplies with the rest of the content in the scene.
  • Max : The max value between the material and the content behind it is used.
  • Min : The min value between the material and the content behind it is used.
  • Screen : The material is blended using the screen blend mode with the rest of the content in the scene.
  • Light : The material is blended using the light blend mode with the rest of the content in the scene.
  • Pre-Mul Blend : The material is premultiplied before blending with the rest of the content in the scene.
  • Off :
  • Refraction :
  • Subsurface Scattering :
  • Single Sided SSS :
Refraction IOR TODO
Aberration TODO
Diffuse Coat TODO
  • Off :
  • On :
Baked Diffuse Intensity TODO
  • Off :
  • On :
Textures
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
UVs
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • Repeat :
  • Clamp :
  • Border With Black :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
  • Repeat :
  • Clamp :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
Lighting
  • Full Reflections :
  • Env Map :
  • Off :
  • Cast + Receive :
  • Cast :
  • Receive :
  • Off :
  • Full :
  • Unseen by Rays :
  • Unseen by Camera :
  • Use Global Settings :
  • Override :
Geometry
  • Front :
  • Back :
  • Double Sided :
FX
  • Off :
  • Rim Lighting :
Rim Lighting Use Material Colour When checked, the colour of the Rim Lighting is defined by the colour of the Material itself
Rim Lighting Colour The colour of the resulting Rim Lighting
Rim Lighting Intensity The Intensity of the resulting Rim Lighting
Rim Lighting Falloff The power factor controlling the Rim Lighting Falloff from the centre of the object
Vertex Colours
  • No :
  • Multiply by RGB :
  • Multiply by Red :
  • Multiply by Green :
  • Multiply by Blue :
  • Multiply by Alpha :
  • Multiply by Inv Red :
  • Multiply by Inv Green :
  • Multiply by Inv Blue :
  • Multiply by Inv Alpha :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
Float ArrayTakes a float array as an inputFloat Array
