Select Input
Switch which input to use in another node.Updated: 15 Sep 2026
Switch which input to use in another node.This nodes allows you to switch the kind of input that goes into a node based on the number of nodes connected to it. Currently, only 3D Meshes, Images and Materials can be connected to this node, and switched between.
This node will filter what can be connected to it based on what the output is connected to. If a node cannot be connected, it’s either because the Select Input Node is connected to a input requiring a different data type, or because the node being connected is of an unsupported type.
| Input Node Index | Select the node you wish to pass through based on its position in the Nodegraph. |
| Inputs | This node will accept any Material, Image, or Mesh connected, but will filter once an output connection is established. | Material |
