Condition Modifier
Condition Modifier
Generate a modifier value when a condition is met.
This node outputs a set value once an input value meets a certain trigger condition.
Threshold Changes the threshold for what counts toward the modifier.
Trigger Mode How the value is modified, once the trigger condition is reached.
  • Constant : As long as the trigger condition is met, the value is output.
  • On Change : Every time the condition changes, the value is triggered once.
  • On Change To True : Once the condition changes to true, the value is triggered once.
  • On Change To False : Once the condition changes to false, the value is triggered once.
Trigger Condition What conditions need to be met for the modifier to be triggered.
  • Greater Than Threshold : The incoming value must be greater than the threshold value.
  • Less Than Threshold : The incoming value must be less than the threshold value.
  • Equal To Threshold : The incoming value must be equal to the threshold value.
