Combine Colour Grades
Combine multiple Colour Grading nodes together.
Combine multiple Colour Grading nodes together before use on an image or scene. All colour grading nodes should be connected as a child to this node to be included in the combined colour grade, with attention paid to their hierarchy.
Through right-clicking the node and selecting “Combine Colour Grade Options”, two options become available:
Name Description
Export Unwrapped Texture LUT As Image Export an unwrapped colour lookup table as a PNG image file.
Export LUT As Cube Export a colour lookup table in the .cube file format, which can then be imported into Notch.
Max Range Set a maximum range between colour grades that will be combined.
HDR Change the precision the attached colour grading nodes are calculated in.
Greyscale Input Only Greyscale the image before it is used by the colour grades.
