Blend Materials
Blend Materials
Updated: 3 Jun 2026
Mix multiple materials together into one material.
This node allows the combination of various materials to form one complex blended material. An input image or Shading node can then be used to control transitions and blends between materials based on the value of the mask source.
The output material can be applied to any node which accepts a material input, such as 3D Objects, Particle Trails, or a Procedural Raytracer.
These properties control the blending of materials.
These properties control attributes of the material.
These properties allow textures to modulate the surfaces. Textures connected to the materials relevant input properties will overwrite these textures.
Alpha Map UV Select the UV to use for the alpha map.
  • Repeat : The texture will tile or repeat endlessly.
  • Clamp : The texture will stop at the edge of the texture space and repeat the edge pixels.
  • Border With Black : The texture will stop at the edge of the texture space and then be black.
  • Mirror : The texture will tile or repeat endlessly, but also mirror each tile.
These properties control how the material interacts with lighting.
Shadows Defines how the object interacts with light in the scene.
These properties control how the material interacts with the properties of the geometry it is applied to.
MaterialsInput for materials that you want to blend.Material
Colour TextureA texture to apply to the object that defines its colour.Video Loader
Diffuse TextureTexture applied spatially to object that defines its diffuse map.Video Loader
