Text Case
Change the case of a Text String.
This node converts all the characters in the string into either lower-case or upper-case, for use within a Text node or to be processed by other text string nodes.
| Text | The text string to change to lowercase. |
| Text Case |
The mode used to transform the input string.
| Text String | Overwrite the text string attribute with an input text string. | Text String |
