Turbulence Warp
Turbulence Warp
Warps an image with a turbulence.
This node warps an image with a turbulence of the screen.
Edge Fade Distance Fades the amount the effect has on the texture from th edges inwards.
Falloff Range Limit the range from which the warp falls off an becomes ineffective.
Animation Rate Control the speed at which the noise is animated.
Mask ImageAdd an image which controls areas which are not affected by the warp effect, using the images luminance.Image Plane
