Sound Modifier
Sound Modifier
Generates a modifier value based on the waveform of an audio source.
This node outputs a modifier value based on amplitude if of of an audio file or a live captured audio input. The audio is split into a series of frequency bands, and the modifier can be set to respond to the amplitude of a specific frequency band, or the amplitude of the whole waveform.
Each increasing band corresponds to a doubling of the band’s center frequency.
This node can receive sound from a Sound Capture or Sound Loader node.
Blend Amount The amount to blend the input modifier’s value with its new value.
Sound Sound file used for the modifier. This can be overwritten with the sound input pin.
Looping Controls whether the sound loops across timeline loops or resets. Only functions if a sound is selected within this node and a sound source isn’t connected to the Sound input.
Restore Values Toggle whether the values restore to 0. If unchecked, generated values incrementally add to the modifier value.
Channel Determines whether the modifier will respond to the left, right, or stereo channels of the incoming sound
Channel Which audio channel is used.
  • Stereo : The modifier will react to both the left and right channels.
  • Left : The modifier will react to the left channel only.
  • Right : The modifier will react to the right channel only.
Frequency Band Sets the Band EQ to a given band. Bands will double in frequency going upwards.
Time Offset Offsets the time the value is modified from the time the waveform is played.
Change Threshold Changes the threshold for what counts toward the modifier.
Attack Controls the initial time between the current value to the peak.
Min Value Acts as a minimum threshold for extracting a range of values from the audio feed.
Max Value Acts as a maximum threshold for extracting a range of values from the audio feed.
Max Clamp Clamps the result.
Spikiness You can use this property limit the rate of change of the output value. A value of 1 will apply no smoothing, a value of 0 will apply maximum smoothing.
Offset Offset the waveform.
Smoothness Adjust the amount of smoothing to applied to the output value.
Modifier Values Read only graph to show the output of the modifier.
EQ Band 0 The gain applied to frequency band 0 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 1 The gain applied to frequency band 1 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 2 The gain applied to frequency band 2 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 3 The gain applied to frequency band 3 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 4 The gain applied to frequency band 4 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 5 The gain applied to frequency band 5 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 6 The gain applied to frequency band 6 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 7 The gain applied to frequency band 7 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 8 The gain applied to frequency band 8 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 9 The gain applied to frequency band 9 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 10 The gain applied to frequency band 10 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 11 The gain applied to frequency band 11 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 12 The gain applied to frequency band 12 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 13 The gain applied to frequency band 13 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 14 The gain applied to frequency band 14 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
EQ Band 15 The gain applied to frequency band 15 of the FFT when analysing audio, from the lowest band (0) to the highest (15).
SoundUse the waveform from a given Sound Loader or Sound Capture node.Sound Loader
