Render To Object Surface
Apply the field to the surface of geometry.Updated: 15 Sep 2026
Apply the field to the surface of geometry.The field is sampled spatially on to the surfaces of visible 3D objects. This is useful for generating fluid effects onto nearby surfaces, and because its volumetric, the generated effect can be applied to the UV map of the 3D object, and rendered out with the UV Camera.
The Render to Object Surface node should be parented to the Field 3D Root node.
This node will not function with the default or Standard Renderer. Consider using the Hybrid Renderer or greater.
| Blend Amount | Changes the alpha of the field. |
| Brightness | Changes the brightness of the field. |
| Sort Bias | Biases the alpha sort in order to make it render in front or behind other transparent objects. |
| Velocity Alpha Scale | The amount the velocity of the field is scaled when it is used to modulate alpha. |
| Blend Mode |
How the render blends with the objects original material colours. See Blend Modes for details.
| Use Field Alpha Channel | Use the field alpha channel when blending with the original surface. |
| Velocity To Alpha | Toggle whether the velocity amount is used to modulate the alpha value, so areas of faster movement are more visible. |
| Affected Object Nodes | Limit the field to only affect a connected piece of geometry. With no object connected, the field will affect all surfaces within the field bounding box. | 3D Object |
| Field Source | The input field source. | Field 3d Root |
