Hilbert Curve
Hilbert Curve
Ggenerates an image with a Hilbert curve pattern.
This node generates a pattern based on a space filling Hilbert curve.
Iteration Sets the iteration count used to generate the curve.
Thickness The thickness of the generated lines in the Hilbert curve.
Switch Entry Direction Switches the entry point of the space filling curve from bottom left edge to bottom edge.
