Ripple Deformer
Ripple Deformer
Displaces geometry using a ripple effect
This node displaces a mesh using a ripple effect which grows from the centre of the deformer to the edge of the falloff.
  • Local :
  • World :
Ripple Direction Control the direction of the ripple.
  • Outwards : Ripple outwards.
  • Inwards : Ripple inwards.
Ripple Speed Speed at which the ripple moves outward from the ripple origin.
Ripple Peak Sharpness How sharp the peaks of the ripple motion are.
Ripple Scale Scales the microripples within the dominant ripple motion.
Ripple Repeat Rate How quickly the ripple animation repeats after the previous ripple.
  • Locked To Timecode :
  • Running / Loopable :
