Points Affector
Use points to disturb a field.Updated: 15 Sep 2026
Use points to disturb a field.This node affects a field by applying positional vortex forces created around points from a particle system, or vertices of a 3D object. This can be used to make a particle system “move through” a field and appear to affect it.
| Velocity Amount | Scale the generated affector velocities. |
| Point Falloff Distance | The inner falloff radius from each point. Outside of this radius, the effect will no longer apply. |
| Point Falloff Power | The sharpness of the falloff from each point. Higher values generate a stronger falloff at the outer falloff distance. |
| Randomness | The randomness of the new velocities added to the simulation. |
| Falloff Mode |
| Falloff Axis |
Which axis the falloff should be oriented on.
| Falloff Direction |
| Falloff Easing Mode |
| Point Source Node | The source of the point data. | Particle Root Node |
| Mask Node | Mask out areas that particles cannot spawn. | Image Plane |
| Procedural Falloff | Input to use a procedural system to control the falloff | Procedural Root |
| Falloff Node | Use an input node to control the properties of the falloff. | Falloff |
