Paint Clones
Paint Clones
Updated: 30 Jan 2026
Gives the user the ability to paint cloned objects onto existing geometry in the viewport.
This node gives the user the ability to paint cloned objects onto existing geometry in the viewport. Each Paint Clones node owns those clones.
Target surfaces #
By default you can ‘place’ new clones on to any geometry in the viewport, unless specific surface nodes are connected as inputs into the
‘Surface Nodes’ input on the node.
Placement of clones #
The following placement operations are provided to place new clones on to geometry surfaces:
  • Placement
    This option allows you to Place new single clones on to surfaces, by first LMB clicking on a surface and click dragging that clone into place.
    You can configure which clone is selected to place by setting the ‘Spawn Mode’ property.
    The ‘Child Number’ option chooses a specific child node to place and will show a new clone hover geometry before placing if it is
    a geometry node (other clonable generative nodes such as Fields or procedurals are also clonable but will not show hover geometry).
    Random or iterative modes will not show the hover geometry.
    Switching the child to place in ‘Child Number’ mode can be set by changing the ‘Child’ property or using the Up and Down keys
    to cycle through them.
    You can scale and rotate new clones before placing on a surface by using scroll-wheel and SHIFT + scroll-wheel, just like viewport placement.
    You can randomise the rotation of new clones by using RMB.
    placementimage image
  • Painting
    This option allows you to Paint many clones at once in a number of ways dependent on the painting option and configuration set.
    In these painting methods, painting is initiated by first LMB clicking and click dragging to paint clones.
    In all painting modes, you can set the ‘Clone Separation’ property to set how far apart painted clones will place on a surface.
    You can either:
    • ‘Point’ paint clones across a surface giving the control like a pencil in a straight line over a surface.
      pointpaintimage image
    • ‘Brush’ paint clones across the area of a brush circle defined by its radius, much like spraying clones around a projected area.
      To change the brush radius either change the ‘Brush Radius’ property directly or use mouse scroll-wheel to change the radius in the viewport.
      To change how many clones are painted in a frame you can set the ‘Spread Flow’ property.
      To change at what frequency clones are painted you can set the ‘Spread Rate’ property.
      brushpaintimage image
Placement and Painting properties #
  • You can place clones offset from a surface, by using the ‘Depth Bias Mode’, either in the direction of the surface normal or towards the camera,
    then setting the ‘Surface Offset’ property to set the offset in metres
  • You can control how new clones are placed and scaled by changing the ‘Clone Overlap’ property
  • The global scale of child nodes cloned can be set by setting the ‘Clone Scale’ property
  • As with other cloners you have a number of spawn modes which will choose a child node to place on a surface in a specific way
  • If not explicitly in ‘Edit’ mode, CTRL + LMB will select a placed clone and you can transform or place those clones after they have been placed on a surface
Erase Mode #
You can erase placed or painted clones by using the Erase Mode.
In Erase Mode you will have a circle with a set radius in the viewport which shows the area of the brush used to erase clones from a surface.
As with the ‘Brush’ mode of painting, you can use the mouse scroll-wheel to change the radius of the erasure brush in the viewport.
LMB clicking and dragging will erase clones under the projected brush area.
You can also erase picked clones by pressing the DELETE key.
brusheraseimage image
Edit Mode #
You can edit placed or painted clones by using the Edit Mode.
In Edit mode you can select a clone by hovering it in the viewport and LMB clicking it to select it.
The default mode after picking the clone in the viewport is placement via the viewport placement tool, you can place,
uniform scale and heading rotate the clone in this mode.
You can also select the viewport translate, rotate and scale handles and transform a clones transform.
Viewport controls #
  • LMB – place or paint clones
  • CTRL + LMB – select a placed clone (you need the Paint Clones node selected before hand or CTRL + LMB twice),
    if not explictly in ‘Edit’ mode where only a LMB click is required to select
  • ESCAPE - deselect a clone
  • RMB – Random Rotate the child before placing on a surface
  • SCROLLWHEEL – Scale the child before placing on a surface
  • SHIFT + SCROLLWHEEL – Rotate the heading of the child before placing on a surface
  • DELETE - Delete the selected clone
  • SCROLLWHEEL – Change the radius of a Brush (painting or erase mode)
  • UP / DOWN keys – In Child Number spawn mode, selects the child to place on a surface
Viewport Sidebar #
A viewport adjacent ‘Side toolbar’ is also provided for easy access to clone painting features.
ViewportSidebarimage image
Nodes that are to be cloned should be connected to the output of this node.
Any geometry node including 3D Objects, Primitives, Lights, Splines and Other Cloners, Clone Effectors may be connected, these nodes aren’t cloned but will act offset and transform all the clones within their area of effect.
Procedurals and Fields are also more examples of clonable systems that can be placed or painted.
Mode Change the clone placement mode.
  • Placement : LMB in viepwort place a clone and drag it into place.
  • Painting : LMB in viewport to continuously paint clones on a surface.
  • Erase : LMB in viewport to erase clones already placed on a surface.
  • Edit : LMB in viewport to edit clones already placed on a surface.
Clone Brush Mode When in Painting mode, change the painting method.
  • Point : LMB to paint clones where the mouse is on the surface.
  • Brush : LMB to paint clones within the brush radius, change the radius by using the Mousewheel.
Brush Radius The brush radius when in Painting and Brush mode.
Spread Flow The amount of clones placed around the surface hit point when in Painting and Brush mode.
Spread Rate The frame frequency clones are placed around the surface hit point when in Painting and Brush mode.
Clone Separation The distance between two clone placements on a surface, set this if you do not want them to overlap.
Depth Bias Mode Change the Depth bias mode, to bias a certain distance from the surface.
  • Normal : Bias along the surface normal.
  • Viewport : Bias off the hit surface, in the direction of the camera.
Surface Offset Surface bias distance, at what distance from the hit surface a clone is offset from.
Clone Overlap Mode Control how a placed clone behaves with respect to surrounding clones already placed.
  • Always : Always place, overlapping clone geometry allowed.
  • Avoid : Always avoid overlapping clones, do not place a clone if it overlaps with another based on bounds.
  • Shrink To Fit : When placing a clone, scale the clone to fit inbetween existing clones.
Clone Scale Global clone scale for all clones placed with this Paint Clones node (scales after placement or before)
Spawn Mode Set the spawn mode of child nodes as clones.
  • All : Place one of each child node with every placement on a surface.
  • Iterate : Iterate over the connected child nodes.
  • Random : Randomly select a child node.
  • Child Number : Use the selected child node (by using up/down arrow keys in the viewport).
Child The selected child node index (use up/down arrow keys to select this or change the property).
New Clone Scale Mode Set the scaling mode of new clones placed on a surface.
  • Uniform : Set the uniform scale along all axis (use scrollwheel to set the scale before placement of new clones).
  • Random : Randomise scaling per axis using the ranges supplied in X/Y/Z Min & Max properties.
  • Uniform Random : Randomise uniform scaling on all axis’ using the range supplied Uniform Scale Min & Max Property.
  • None : Take the child node scale as placed clone’s scale.
New Clone Scale When in Uniform scaling mode, set this property as the scale (also set using scrollwheel in the viewport).
Uniform Scale Min & Max Set the Range of values to randomise the scale uniformally.
Randomise Scale Set the scaling axis that should be randomised, if Random scale is enabled.
X Min & Max Set the Range of values to randomise the X axis.
Y Min & Max Set the Range of values to randomise the Y axis.
Z Min & Max Set the Range of values to randomise the Z axis.
New Clone Rotation Mode Set the rotation mode of new clones placed on a surface.
  • Normal : Align placed clones along the normal of the hit surface.
  • Normal Random Heading : Align placed clones along the normal of the hit surface, randomise the heading rotation along that axis.
  • Random : Randomise rotation per axis using the ranges supplied in H/P/B Min & Max properties.
  • None : Take the child node rotation as placed clone’s scale.
New Clone Rotation When in Align To Normals rotation mode, set this property as the Heading rotation offset (also set using scrollwheel + SHIFT key in the viewport).
Randomise Rotation Set the rotation axis that should be randomised, if Random scale is enabled.
H Min & Max Set the Range of values to randomise the Heading axis.
P Min & Max Set the Range of values to randomise the Pitch axis.
B Min & Max Set the Range of values to randomise the Bank axis.
Inherit Surface Colour Sets mode where each clone inherits the colour of the surface it is painted on.
Paint On Clones Activates the ability to paint on already painted clones attached to this paint clones node.
Clear Clones Clears all clones on this clonepainter node.
Clone Count Number of clones currently painted.
Surface NodesAttach geometry nodes that can be used as a canvas, if none attached, all nodes in view of camera are used as painting canvas3D Object
