Auto Key Colour Mask
Updated: 15 Oct 2026
Automatically generate a mask for an image.
This node automatically creates a keyed mask for a video, generally useful for Green screen video. After some further touch up, the key can be further improved to being of reasonably good quality, but for the best quality, use the Chroma Key node.
| Output Mask Only | Toggle whether to only output the greyscale mask. |
| Invert Mask | Invert the greyscale output mask. |
| Blend Mode | Choose how the image blends with the scene. See Blend Modes for details. |
| Process HSV | Toggles whether processing is done in HSV colour space. |
| Show Colours | Visualise the colours that were extracted from the input image and used for auto-keying. |
| Hardness | Change the hardness at the edges of the mask |
| Vignette Width | Controls the width of the centre vignette, inside which the weight of likeliness of colours being used as key colours is reduced. |
| Colour Difference | The threshold of tolerance of difference between key and source pixel colours, inside which the pixel is considered visible / part of the mask. |
| Hue Difference | Toggles whether processing is done in HSV colour space. |
| Saturation Difference | Control the difference in saturation. |
| Luminance Difference | Control the difference in luminance. |
| Key Colour Source Image | The image colour you want to key out. | Video Loader |
| Vignette Mask Image | Image gradually fades into the background. | Video Loader |
