Particle 3D Emitter
Emits ink into a field from particles
This node generates colour/ink based on the positions and movement of particles from a particle system. The particles contribute both ink and velocities to the field.
| Particle Radius | The particle radius. |
| Emission Mode | When to emit. |
| Colour | The colour to emit. |
| Density | The amount of density to emit. |
| Temperature | The amount of temperature to emit. |
| Velocity | The scale of the velocity to emit. velocities are generated from particle motion; a velocity scale of 1 emits the particle’s velocity as-is. |
| Hardness | Reduces the emission rate around the edges of the emission area to create softer looking edges. |
| Fractal Noise Amount | The amount of fractal noise to apply to the emitted density. |
| F Noise Scale | The scale of the fractal noise. |
| F Noise Threshold | The threshold to apply to the fractal noise. |
| Explode Velocity | The explode velocity. |
| E Noise Scale | The scale of the fractal noise used to generate the explode velocity. |
| E Noise Threshold | The threshold to apply to the fractal noise used to generate the explode velocity. |
| Pyroclastic Displacement | The amount of pyroclastic displacement. |
| P Noise Scale | The scale of the fractal noise used to generate the pyroclastic displacement. |
| Particle Node | Used to connect the particle system used by the emitter. | Particle Root |
| Density Nodes | Shading node input for controlling emitter density. | Fractal Noise |
| Temperature Nodes | Shading node input for controlling emitter temperature. | Fractal Noise |
| Fuel Nodes | Shading node input for controlling emitter fuel amount. | Fractal Noise |
| Colour Nodes | Shading node input for controlling emitter colour. | Fractal Noise |
| Velocity Nodes | Shading node input for controlling emitter velocity. | Fractal Noise |
