Frame Delay Frame
Frame Delay Frame
Delays the image played by a specified frame amount.
This node delays the image played by a specified frame amount, based on an input frame delay node. Requires a Frame Delay input to function, with a “num frame delay” larger than this nodes frame index value.
Legacy Effect Mask Blend Blend input masks using the legacy behaviour kept for pre-2022 scenes. Leave disabled for new compositions.
Frame Index Control how many frames are stored for delay.
Frame DelaySource Frame Delay node from which the buffered frames are pulled from.Frame Delay
