Screen Warp
Adds a bulge effect to the image.
This node adds a bulge effect to the image, whereby a chosen point is stretched and the outer edge is squashed.
| Amount | How strong the warp is. |
| Inner Radius | Radius size of the focus of the warp. |
| Outer Radius | The outer radius of the warp. |
| Effect Amount Image | Input to control the amount of the effect based on the colour data of an image. | Gradient |
