MOVIN Mocap Skeleton
Updated: 20 Jan 2026
Control skeletal rigs from a MOVIN mocap system.
This node reads bone data from the MOVIN TRACIN Motion Capture System and applies it to Bone nodes, either via direct input links or by a connection to the root of the target hierarchy.
A network connection must be made to the MOVIN Studio software which provides a stream of bone data from the LIDAR hardware via an ethernet cable and OSC.
The input skeleton the node is applied to must have been designed to receive motion capture data: the bones must be named, oriented and arranged appropriately. Mixamo rigs are a good reference.
OSC must be enabled and to match the output address and port in the MOVIN software. If there is no connection the node will be hatched out in red.
Please be advised you can only import one live stream into a notch project at a time.
If issues with the MOVIN Mocap setup before streaming into Notch arise, refer to the Official MOVIN Documentation.
Actor Name The name of the actor to bind to, as configured in the MOVIN software.
Select Actor Name List of actors discovered on the network. Pick the actor whose skeleton this node should output.
Input Skeleton Scale Uniformly scale the size of the input mocap skeleton.
Keep Alive Time How long (in seconds) an unfound actor retains its last known pose before the node reports it as lost.
Hierarchy RootThe root of the input skeleton to be driven by motion capture.You’ll need to connect the skeleton root within an 3D Scene.
Mocap StreamInput a pre-recorded mocap stream to run instead of any live data.Mocap Stream
RootThe transform of the root joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone.Null
