Fluid 2D Affector
Fluid 2D Affector
Applies a fluid simulation to a field.
This node applies a fluid solver to the velocities of the field system, creating eddies and swirls like a gas or liquid. This solver uses the grid-based Navier Stokes method, maintaining incompressible pressures using multiple iterations of a process over the field’s voxel grid, and can have a sizeable performance impact with high-resolution fields.
Vorticity Confinement Scale Controls the amount of vorticity confinement, which increases the number of small swirls in the fluid system.
Diffusion Amount How much the field colours are diffused to neighbouring voxels.
Velocity Dampening How much velocities are dampened and averaged across the field system.
Expansion By Temperature Expand fluid cells according to their temperature, driving buoyant convection.
Temperature Vorticity Amplification Amplifies vorticity in proportion to cell temperature, curling hot regions of the fluid more than cool ones.
Velocity Vorticity Amplification Amplifies vorticity in proportion to cell velocity, encouraging eddies in fast-moving regions.
Solver Iterations How many times the fluid system solver is run. Higher values improve accuracy, but lower performance.
Solver Pre-Smoothing Iterations The number of smoothing passes applied to the pressure field before solving.
Advect Mode Method by which the advection of properties from one cell to another is calculated.
  • Maccormack :
  • Simple :
  • Runge-Kutta :
Maccormack Advection Factor Strength of the MacCormack correction applied during advection, which sharpens fluid detail. Lower values blend back towards simple linear advection.
Downsample Velocity Run velocity advection at half resolution to improve performance, at the cost of some fine detail.
