Field Colour Ramp Material
Updated: 2 Feb 2026
Uses a colour ramp to colour a field system based on density or temperature. The field will fade through the colours in the ramp as the density/temperature get higher or lower.
Updated: 2 Feb 2026
The field colour ramp material is suitable for colouring the field system based on attributes such as density or temperature. If you input a Colour Ramp to the temperature or density colour ramp input, the field will take its current density/temperature value and assign a colour based on the Colour Ramp. Lower values will pick colours from the left side of the ramp and higher ones from the right side. You can control how values are picked along the ramp by using the Temperature Curve Power property.
| Tint Colour | Tints the field. |
| Density | Density of the field. |
| Scattering | The ratio of scattering vs absorption. |
| Scattering Colour | Controls the ratio of scattering vs absorption per colour channel. |
| Density Colour Ramp Blend | Control the amount that the density colour ramp affects the field system. |
| Temperature Emissiveness | Control how emissive the colour generated by the temperature colour ramp is. |
| Temperature Curve Power | Control the shape of the curve which the colours will be selected from along the colour ramp |
| Modulate Temperature Colour By Density | Should density affect the brightness of the temperature colour. |
| Density Nodes | Shading node input for controlling the overall density of the field system. | Fractal Noise |
| Colour Nodes | Shading node input for controlling the overall colour of the field system. | Fractal Noise |
| Emissive Colour Nodes | Shading node input for controlling the overall emissive colour of the field system. | Fractal Noise |
| Temperature Colour Ramp | Colour ramp input to control the colour of the field system based on the temperature | Colour Ramp |
| Density Colour Ramp | Colour ramp input to control the colour of the field system based on the density | Colour Ramp |
