Continuous Modifier
Generates a continually increasing modifier value.Updated: 15 Sep 2026
Generates a continually increasing modifier value.This modifier continually increments or decrements the targeted parameter value at a constant rate.
| Speed | The speed at which the modifier increases (per second) |
| Modifier Operation |
| Time Mode |
How the modifier updates in relation to the time code.
