Combine Geometry
Merge multiple sources of geometry into one.
Combine multiple sources of geometry into one to be used or affected by other nodes. This particularly great for use with cloner systems, where the geometry can be combined together and deformed collectively.
| Make Clone UVs Unique | Force the UVs of cloned meshes to be combined into a single uv map with each clone taking up a separate island. |
| Make Diffuse/Lightmap UVs Unique | Force the Diffuse UVs to be generated into a single uv map with each mesh taking up a separate island. Useful for baking lighting, so all mesh UVs are treated separately. |
| Retain Source Materials | Keep the source materials and mappings from the input meshes, and apply them to the combined mesh. |
| Chunks Mode | preserve chunks from input geometry or not. |
| Seen By Rays | Allow the mesh to be seen by the raytracer. When set to 0, the mesh will still render in camera but will be ignored by any raytracing nodes. |
| Per Object Composite Alpha | Overwrites the alpha channel beneath the object, giving simple effect of transparency. Best used when the mesh won’t overlap with other objects, as other meshes will not be seen through the mesh. |
| Lines Visible | Control whether lines are rendered to the scene from the geometry. |
| Lines Alpha | Change the alpha transparency value of the lines, making them appear see-through. |
| Colour | Change the colour value of the lines. |
| Use Vertex Colours | Colour lines based on the vertex colours of the geometry. |
| Blend Mode |
How the object lines blends with the rest of the content in a 3d scene. See Blend Modes for details.
| Thick Lines | Allow the lines to rendered with thickness, for line effects which can be accurately anti-aliased. |
| Thick Line Width | Control the thickness of all the lines. Only functions with Thick Lines enabled. |
| Hide Back Face Lines | Hide the lines generated from polygon faces facing away from the camera, where only the back faces of geometry can be seen. |
| Lock Width | Lock the line width to be a consistent width regardless of distance from the camera. Only functions with Thick Lines enabled. |
| Show Silhouette Lines | Draws lines along the edges of the object relative to the camera. |
| Show Normal Difference Lines | Draw a line along the edges of the mesh, depending on the angle difference between their mutual faces. |
| Show Unshared Lines | Draw lines along all edges of the shape. |
| Show Other Lines | Show all the lines for each edge of the mesh. |
| Unshared Lines Weight | Control the strength of the unshared lines. |
| Silhouette Lines Weight | Control the strength of the silhouette lines. |
| Normal Difference Lines Weight | Control the strength of the lines generated along the normal angles. |
| Other Lines Weight | Control the strength of the lines for each edge in the mesh. |
| Line Normal Difference Angle | Change the threshold angle between two face normals that will generate a line along their common edge. Only functions with Show Normal Lines enabled. |
| Line Normal Fade Sharpness | How much the drawn normal lines will fade away the closer the edge angle is to the Line Normal Difference Angle. |
| Line Depth Bias | Exaggerate the width of the lines based on the distance to the camera. not functional with Lock Width enabled. |
| Line Silhouette Fade Sharpness | How much the drawn silhouette lines will fade away based on the size of the edge angle to the camera. |
| Preview in Viewport | Toggle a preview of the Material on a sphere in the Viewport. |
| Colour | The colour of the material. |
| Brightness | The brightness of the material. |
| Colour Map -> Specular Colour | Use the input colour map as the specular reflection colour. |
| Metallicness | Controls the metallicness of the material. |
| Normal Map Mode |
| Normal Map Intensity | TODO |
| Invert Normals | Flip the normals of each face, so the lighting is tested against the inside face. |
| Emissiveness | How much of a glow is emitted around the object. |
| Emissive Scattering | Controls how much Emissive lighting is scattered in the scene. |
| Emissive Lights Scene | Controls how much Emissive lighting contributes to lighting the scene. |
| Use Displacement |
Enables the use of displacement mapping for the material. *Requires an input displacement map.
| Displacement Offset | Adds an initial offset to the displacement. |
| Displacement - Use Polygon UVs | TODO |
| Opacity Mode |
Controls the opacity mode of the material, and how it blends with the scene.
| Alpha | Set the alpha amount of the material |
| Blend Mode |
Change how the material once added to an object blends with the scene. Only functions with Alpha Mode for details.
| Alpha Sort Bias | Biases the alpha sort in order to make it render in front or behind other transparent objects. |
| Output Alpha In GBuffer Composite | Sends the alpha to the gbuffer composite pass. |
| Translucency |
| Refraction IOR | TODO |
| Aberration | TODO |
| Absorption | How much light is absorbed by the material as light passes through it. |
| Absorption Colour | Colour to use for absorption. |
| Subsurface Weight | Weight of the subsurface scattering effect. |
| Subsurface Scatter Radius | Radius of the subsurface scattering effect. |
| Diffuse Coat | TODO |
| Diffuse Lightmap |
Enables an input diffuse lightmap for the material.
| Baked Diffuse Intensity | TODO |
| Ambient Occlusion |
Enables the input ambient occlusion map of the material.
| Diffuse Map | Specifies the color of light that scatters off the surface in all directions. It is functionally similar to the Colour Texture and is a core component of a material’s appearance. |
| Emissiveness Map | Determines which parts of a material appear to glow or emit their own light. Brighter values cause the surface to act as a light source. |
| Metallicness Map | A grayscale map to define how ‘metal-like’ a surface is. White values represent pure metal, while black values represent non-metals. |
| Alpha Map | A grayscale map that controls the transparency of the material. Black areas are fully transparent, white areas are fully opaque, and gray values create semi-transparency. |
| Ambient Occlusion Map | Adds subtle, soft shadows to areas that are occluded from ambient light, such as creases and crevices. This enhances realism and adds perceived depth to the model. |
| UV Texture Filter Mode |
| Diffuse Map -> AO | A setting to use the Diffuse or Colour map to contribute to the Ambient Occlusion calculation, often darkening areas based on the base color. |
| Colour Texture UV |
Select the UV for the Colour Texture.
| Diffuse Map UV |
Select the UV for the Diffuse Map Texture.
| Specular Map UV |
Select the UV for the Specular Map Texture.
| Emissiveness Map UV |
Select the UV for the Emissiveness Map Texture.
| Metallicness Map UV |
Select the UV for the Metallicness Map Texture.
| Roughness Map UV |
Select the UV for the Roughness Map Texture.
| Normal Map UV |
Select the UV for the CoNormal Map Texture.
| Displacement Map UV |
Select the UV for the Displacement Map Texture.
| Alpha Map UV |
Select the UV for the Alpha Map Texture.
| Ambient Occlusion Map UV |
Select the UV for the Ambient Occlusion Map Texture.
| Subsurface Colour Map UV |
Select the UV for the Subsurface Colour Texture.
| Subsurface Weight Map UV |
Select the UV for the Subsurface Weight Texture.
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Lit | Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting. |
| Reflections Mode |
| Shadows |
| Shadow Catcher Colour | Set the colour of the material when “Shadows” is set to “Shadow Catcher”. |
| Render Visibility |
Controls the object’s visibility to different types of rays in the renderer, which is useful for advanced effects.
| Raytracing Settings |
| Polygon Sidedness |
| Rim Lighting |
Simulates Rim Lighting on the material with respect to the camera.
| Rim Lighting Use Material Colour | TODO |
| Rim Lighting Colour | TODO |
| Rim Lighting Intensity | TODO |
| Rim Lighting Falloff | TODO |
| Vertex Colours - Apply To Colour |
Set how the vertex colours apply to the colour of the mesh.
| Vertex Colours - Apply To Alpha |
Set how the vertex colours apply to the alpha of the mesh.
| Vertex Colours - Apply To Roughness |
Set how the vertex colours apply to the roughness of the mesh.
| Vertex Colours - Apply To Metallicness |
Set how the vertex colours apply to the metallicness of the mesh.
| Vertex Colours - Apply To Emissiveness |
Set how the vertex colours apply to the emissiveness of the mesh.
| Static Friction | How much resistance there will be for rigid bodies that are at rest relative to each other to begin moving. |
| Friction | How much other rigid bodies will be able to slide along side this rigid body. When two rigid bodies of different frictions interact, the minimum value is used. |
| Bounciness | How much this rigid body will bounce off of other rigid bodies in the scene. |
| Density | The density of the rigid body. The density is scaled by the area of the shape to determine the mass of the body. |
| Dynamics Mode |
How the object is used in a physics simulation. Parenting to a Physics Root node node must be done for any physics simulations to occur.
| GPU Transform Only | If selected, the transform of the body is maintained on GPU only. This reduces latency and increases performance but means that parenting to the object, e.g. using it to transform lights or emitters, will not work. |
| Rigid Body Shape |
The shape of the rigid body used for physics simulation. Often times, a simpler approximation of a mesh can be used for significantly improved performance.
| Rigid Body Convex Hull Mode |
Determines the convex hull shape generation used to wrap around the node’s geometry. only functions if the Convex Hull shape is selected in the Rigid Body Shape.
| Rigid Body Chunks Mode |
Set whether to treat the object as one single rigid body, or whether to calculate physics for each chunk.
| Max Chunks | When using ‘Multi Body’ chunk mode, set the maximum amount of chunks that can be calculated. Useful for performance optimisation. |
| Mass Center X | Adjust the object’s center of mass along the X axis |
| Mass Center Y | Adjust the object’s center of mass along the Y axis |
| Mass Center Z | Adjust the object’s center of mass along the Z axis |
| Advanced | TODO |
| Collision Radius | The radius of collision shape if applicable. |
| Collision Mode |
Mode for calculating collision if applicable.
| Rigid Body Sphere Radius | TODO |
| Rigid Body Box Size X | TODO |
| Rigid Body Box Size Y | TODO |
| Rigid Body Box Size Z | TODO |
| Bake Physics Transforms | Bake physics transforms so they are no longer dynamic, but reliably playback and are more performant. |
| Baked Transform | Select the baked physics transform. |
| Geometry Sources | Sources of geometry to be combined into a single object. | 3D Primitive |
| Material | Override the default material with a material node. | Materials |
