Colour Ramp Effector
Modifies a cloner system with colours from a Colour Ramp input.
This node primarily modifies the colour values of connected cloner systems based on an input Colour Ramp, but can also apply transformations to the clones too based on the area of effect of the colour ramp.
Colour Blend Mode How the colour blends with other colour data.
Colour Blend Amount How much the colour blends with the original clones colour.
Source Channel What property of the clones in relation to the effector should be used to dictate colour.
  • Position X : Clones are coloured based on their X position.
  • Position Y : Clones are coloured based on their Y position.
  • Position Z : Clones are coloured based on their Z position.
  • Distance : Clones are coloured based on their radial distance from the effector.
  • Fractal Noise : Clones will be coloured based on a simple fractal noise function.
  • Clone Index : Clones will be coloured based on their index.
  • Random Value : Clones are coloured completely randomly with the input colour ramp.
Source Scale Scale the size of the source Colour Ramp.
Source Offset Offset the values from the source Colour Ramp.
Modulate Function The method by which the colour ramp is sampled / repeated.
  • Clamp : The sample locations are clamped from 0 to 1.
  • Repeat : The sample locations are repeated.
  • Sine : The sample locations are modulated with a sine wave.
Interpolate Colours Allow the clones to interpolate the colours passed to them, smoothing the colour changes across the clones.
Noise Scale Scale the size of the generated fractal noise. Only functions with Fractal Noise selected in the Source Channel Attribute.
Lacunarity How large the gaps between larger areas of noise are. Only functions with Fractal Noise selected in the Source Channel Attribute.
Gain The overall smoothness of the generated fractal noise. Only functions with Fractal Noise selected in the Source Channel Attribute.
Animation Rate The speed at which the fractal noise is animated. Only functions with Fractal Noise selected in the Source Channel Attribute.
Colour RampControls the colours and ranges of colours used to tint the clones.Colour Ramp
