Glass Material
Add a transparent glass material.
This node generates a basic glass material, similar to the default material node but with default raytraced glass settings.
| Preview in Viewport | Toggle a preview of the Material on a sphere in the Viewport. |
| Colour Map -> Specular Colour | Use the input colour map as the specular reflection colour. |
| Normal Map Mode |
| Use Displacement | Enables the use of displacement mapping for the material. *Requires an input displacement map. |
| Translucency |
| UV Texture Filter Mode |
| Subsurface Colour Map UV | Select the UV for the Subsurface Colour Texture. |
| Subsurface Weight Map UV | Select the UV for the Subsurface Weight Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Reflections Mode |
| Shadows |
| Raytracing Settings |
| Polygon Sidedness |
| Vertex Colours - Apply To Alpha | Set how the vertex colours apply to the alpha of the mesh. |
| Normal Map Intensity | TODO |
| Invert Normals | Flip the normals of each face, so the lighting is tested against the inside face. |
| Displacement Offset | Adds an initial offset to the displacement. |
| Displacement - Use Polygon UVs | TODO |
| Refraction IOR | TODO |
| Aberration | TODO |
| Absorption | How much light is absorbed by the material as light passes through it. |
| Absorption Colour | Colour to use for absorption. |
| Subsurface Weight | Weight of the subsurface scattering effect. |
| Subsurface Scatter Radius | Radius of the subsurface scattering effect. |
| Diffuse Coat | TODO |
| Rim Lighting Use Material Colour | TODO |
| Rim Lighting Colour | TODO |
| Rim Lighting Intensity | TODO |
| Rim Lighting Falloff | TODO |
| Resolution Limits |
TODO
| Max Width |
TODO
| Max Height |
TODO
This node has no inputs.
| Colour Texture | A texture to apply to the object that defines its colour. | Video Loader |
| Diffuse Texture | Texture applied spatially to object that defines its diffuse map. | Video Loader |
| Specular Map | Texture applied spatially to the object that defines its specular. | Video Loader |
| Emissiveness Map | Texture applied spatially the object that defines its emissiveness. | Video Loader |
| Metallicness Map | Greysacle texture applied spatially to the object that defines its metallicness. | Video Loader |
| Roughness Map | Greyscale texture applied spatially to the object that defines its roughness. | Video Loader |
| Normal Map | Texture applied spatially to the object that defines its normals. | Generate Normal Map |
| Displacement Map | Texture applied spatially to the object that displaces the vertices of the model’s geometry. | Video Loader |
| Alpha Map | Texture applied spatially to the object that defines its transparency. | Video Loader |
| Ambient Occlusion Map | Texture applied spatially to the object that defines its ambient occlusion. | Video Loader |
| Subsurface Colour Map | Texture applied spatially to the object that defines its subsurface colour. | Video Loader |
| Subsurface Weight Map | Texture that controls the intensity of the subsurface scattering effect. | Video Loader |
| Composite Nodes | Use shader nodes to override the compositing stage of the shader pipeline. | Channel Sampler |
| Mapping | Control how the image input is mapped onto the mesh for displacement. | Mapping |
