Face Tracking Deformer
Deforms geometry based on input face tracking data
This node uses the vertex data from a tracked face found by the Face Tracker node to override the vertex positions of the 3D object node the deformer is attached to - if that 3D object conforms to the structure of the geometry generated by the face tracker.
This allows face tracking to be used to deform a pre-created, imported 3D object that has been designed to be used with face tracking. An example of such an object is available here.
For more information on face tracking, see the Face Tracker node.
  • Local :
  • World :
Face TrackerSource face tracking data for deforming the parent.Face Tracker
