Render To Surfaces
Render the connected nodes onto object surfaces.Updated: 15 Sep 2026
Render the connected nodes onto object surfaces.This node renders connected objects and lights onto the surface of chosen objects.
| Width | Width of rendered texture. |
| Height | Width of rendered texture. |
| Background Colour | Change the background colour of the rendered texture. |
| Disable Render To Texture (Pass Through) | When enabled, the texture rendering will be ignored and the child nodes will be passed through into the main scene. |
| Use 360 Degree Camera | Render onto surfaces using a 360 degree camera mapping. |
| Target Surfaces | Select which surfaces will have the rendered image applied to them. | 3D Object |
| Rendered Nodes | Add nodes which will be included in the rendered scene. | 3D Object |
| Affecting Lights | Choose which lights will affect connected objects. | Light |
| Excluded Lights | Choose which lights wont affect connected objects. | Light |
