Delay Value
Delay Value
Delays the output of modifier over time.
This node delays the output of an input modifier by a time frame set by the Delay Time.
Delay Time Time in seconds the output value should be delayed by. Above 10, it will run out of space in its buffer and will no longer delay input values.
