Trail Renderer
Trail Renderer
Renders trails which follow the path of particles.
This node generates trails of lines or points along the path of individual particles to create trail-like effects. This is done by sampling the particle position at regular time intervals and storing the samples as control points in a path buffer. The size of the path buffer is finite so only a limited number of control points per particle may be stored, which in turn limits the visual length of the generated trail.
You can deform the generated geometry trails with Deformer Nodes.
Particle Alpha Change the alpha value for the particles.
Blend Mode Edit the blend mode used for the particles. See Blend Modes for details.
Line Thickness Edit the thickness of the line rendered. Only functions if Use Thick Lines is turned on.
Minimum Line Thickness Minimum thickness allowed when using “Thickness Randomness”.
Thickness Randomness Add randomness to the thickness of the lines.
Line Softness Change the thickness of the gradient along the edge of the line.
Luminance How bright the drawn trail is.
Luminance Randomness How much rnadomness there is in the brightness of the drawn trail.
Cast Shadows Control whether shadows are cast.
These properties control how the particle trails are generated.
Control Point Time Spacing The minimum distance allowed between control point samples.
Control Point Distance Spacing Distance between trail control points. At 0 the trail follows every emitted particle exactly; higher values space points further apart for longer, smoother trails.
Trail Fade Mode Select how the trail fading is calculated.
  • Time : Trail fades based on the timeline.
  • Length : Trail fades on the length of the trail.
  • Age : Trail fades based on the age of each particle.
Trail Decay The rate of decay for control point samples. Only functions with Time set in Trail Fade Mode.
Trail Fade Length Set the length at which the particles fade off at. Only functions with Length set in Trail Fade Mode.
Trail Fade Age Set the age at which the particles fade at. Only functions with Age set in Trail Fade Mode.
Trail Fade Range How aggressively the particles fade away.
Num Trail Vertices Change the number of vertices generated to form the trail.
Num Radial Segments Change the number of sides to the extruded geometry. Extruded Geometry must be selected in the Primitive Types attribute.
BSDF
  • Off :
  • Tangent Space :
  • Object Space :
Normal Map Intensity Controls the intensity of an input Normal Map
  • Off :
  • On :
Displacement - Use Polygon UVs Use the UVs of each polygon when applying Displacement
  • Solid :
  • Blend :
  • Clip :
  • Solid : The material is treated as a solid object, and does not blend with anything behind it.
  • Linear : The material is blended with the rest of the content in the scene.
  • Additive : The material adds onto the rest of the content in the scene.
  • Subtractive : The material subtracts from the rest of the content in the scene.
  • Multiply : The material multiplies with the rest of the content in the scene.
  • Max : The max value between the material and the content behind it is used.
  • Min : The min value between the material and the content behind it is used.
  • Screen : The material is blended using the screen blend mode with the rest of the content in the scene.
  • Light : The material is blended using the light blend mode with the rest of the content in the scene.
  • Pre-Mul Blend : The material is premultiplied before blending with the rest of the content in the scene.
  • Off :
  • Refraction :
  • Subsurface Scattering :
  • Single Sided SSS :
Refraction IOR TODO
Aberration TODO
Diffuse Coat TODO
  • Off :
  • On :
Baked Diffuse Intensity TODO
  • Off :
  • On :
Textures
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
UVs
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • Repeat :
  • Clamp :
  • Border With Black :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
  • Repeat :
  • Clamp :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
Lighting
  • Full Reflections :
  • Env Map :
  • Off :
  • Cast + Receive :
  • Cast :
  • Receive :
  • Off :
  • Full :
  • Unseen by Rays :
  • Unseen by Camera :
  • Use Global Settings :
  • Override :
Geometry
  • Front :
  • Back :
  • Double Sided :
FX
  • Off :
  • Rim Lighting :
Rim Lighting Use Material Colour When checked, the colour of the Rim Lighting is defined by the colour of the Material itself
Rim Lighting Colour The colour of the resulting Rim Lighting
Rim Lighting Intensity The Intensity of the resulting Rim Lighting
Rim Lighting Falloff The power factor controlling the Rim Lighting Falloff from the centre of the object
Vertex Colours
  • No :
  • Multiply by RGB :
  • Multiply by Red :
  • Multiply by Green :
  • Multiply by Blue :
  • Multiply by Alpha :
  • Multiply by Inv Red :
  • Multiply by Inv Green :
  • Multiply by Inv Blue :
  • Multiply by Inv Alpha :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
Primitive Type Change the shape that trails behind the particle.
  • Lines :
  • Thick Lines :
  • Thick Lines (Simplified) :
  • Extruded Geometry :
  • Line Geometry :
MaterialInput a material to be used by the trail when in Extruded Geometry mode.Materials
